How do I replace a broken zip slider on my Vaude clothing?
  1. How do I replace a broken zip slider on my Vaude clothing?, zip slider: step 1, image 1 of 3 How do I replace a broken zip slider on my Vaude clothing?, zip slider: step 1, image 2 of 3 How do I replace a broken zip slider on my Vaude clothing?, zip slider: step 1, image 3 of 3
    • Select a replacement slider and zip stop.
  2. How do I replace a broken zip slider on my Vaude clothing?: step 2, image 1 of 1
    • Remove the zip stop at the end of the zip by prying it open with a wire cutter and pulling it away.
  3. How do I replace a broken zip slider on my Vaude clothing?: step 3, image 1 of 1
    • Remove the broken slider.
  4. How do I replace a broken zip slider on my Vaude clothing?: step 4, image 1 of 1
    • Insert the new slider onto the zip and use the wire cutter to press the zip stop into the position where the old stop had been.
  5. How do I replace a broken zip slider on my Vaude clothing?: step 5, image 1 of 3 How do I replace a broken zip slider on my Vaude clothing?: step 5, image 2 of 3 How do I replace a broken zip slider on my Vaude clothing?: step 5, image 3 of 3
    • Positon the zip stop together with the help of the tweezers.
    • Pinch the zip stop together with the help of the tweezers.
  6. How do I replace a broken zip slider on my Vaude clothing?: step 7, image 1 of 1
    • Remove the zip puller (black) from the slider and thread it onto the new slider.
Done! You made it.
9 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VAUDE Reparaturteam
6,255 Reputation
32 Guides authored
Vaudesport Member of Vaudesport
Community
3 Members
96 Guides authored
6 Comments
Eine tolle Idee, diese Anleitungen und würde auch gerne mein geliebtes Radtrikot reparieren. Ich habe nur das Problem, dass ich den defekten Schieber von meinem Radtrikot Matera nicht identifizieren kann. Können Sie mir da weiter helfen?
rosselba - Reply
Hallo Rosselba, Prinzipiell steht immer hinten auf den Slidern eine Buchstaben/ Zahlen - Kombi. Anhand der kann man ablesen welcher Slider als Ersatz passen würde.
VAUDE Reparaturteam - Reply
Links zu den Ersatzteilen könnten besser sein. Komme immer zuerst auf Angebote für neue Kleidung..
Jochen Klingbeil - Reply
Bei ausgeleierten Schiebern hilft es auch oft, diesen an der offenen Seite mit einer Zange leicht zusammenzudrücken. Das hat bei mir schon häufig funktioniert und es geht sehr schnell.
Beste Grüße
Emanuel - Reply
Hi
Zipper sliders are available here: https://www.shelby.fi/?cPath=402_31_82
For example the type in pictures: https://www.shelby.fi/product_info.php?p...
Stoppers available here: https://www.shelby.fi/product_info.php?c...
(this one is easier to install than the one in pictured in instructions)
order - Reply
And when zipper has 2 sliders and it is broken due wear (most common), it always lots of sense to replace both upper and lower slider.
Shelby Oy - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 53
All Time: 5,718
