Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
LED daytime running lights are a great add-on to any vehicle to increase light output for style and safety. Some LED daytime lamps are vehicle specific, but this set of Philips Style LED DRL is universal fit for more cars and SUVs.
  1. Insert the wire into the bracket.
    • Insert the wire into the bracket.
  2. Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
    • Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
  3. After mounting the bracket, you can lock the LED daytime running light on the bracket.
    • After mounting the bracket, you can lock the LED daytime running light on the bracket.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Connect the wires and route the wires up and near the fuse box. Use zip ties to tie the wire along the bumper.
    • Connect the wires and route the wires up and near the fuse box.
    • Use zip ties to tie the wire along the bumper.
  6. Find the ACC in your fuse box and tap the red wire there. You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
    • Find the ACC in your fuse box and tap the red wire there.
    • You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
    • When you find ACC, tap the red wires to the blade of the fuse and insert it back.
  7. Tap the black wire to battery negative.
    • Tap the black wire to battery negative.
  8. Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights. Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights. Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
    • Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
As you can see, installation isn't complicated and if you follow the directions accordingly, you'll be on your way to new LED daytime running lights in no time.
19 other people completed this guide.
Eric Wu
2,889 Reputation
23 Guides authored
10 Comments
Useful information shared. Thanks for giving us nice info. Fantastic walk through. I appreciate this post and here is my link
http://optixautolabs.com/
Calvin Macaraeg - Reply
Useful info. Thanks
grant.edson - Reply
great information and pictures, just one thing, what size of fuse should I use for connection in fuse box.
steve finlayson - Reply
UK road/MOT law states you must 60% dim or better still, make DRL’s turn off when headlights are turned on … stop advertising fake information Phillips and start stating some facts for a change
i cry when i wii - Reply
When did Philips ever make a comment on brightness? Its your responsibility to ensure you meet MOT regulations, not theirs.
AdamA -
Wot about the indicator wire
Andrew Mcdonagh - Reply
Indicator has nothing to do with it as these aren’t switchback
AdamA -
Hello. Can I wire 2 drl to this same fuse?
Bálint Rónai - Reply
The wire connection directly to the ACC fuse is both unsafe and unprofessional. Using the method you describe, if the LED DRL, or a bare wire causes the fuse to blow, all ACCessories will be disabled. Also, your description doesn't ensure you are connected to the back side of the fuse, anyway. The proper connection would be a quick-tap splice to the back-side wire of the ACC fuse with a separate in-line fuse for the DRL. That way, if the DRL overloads the fuse, only the in-line fuse will be blown and the rest of the ACCessories will still have power.
Herman Spoot - Reply
Past 24 Hours: 26
Past 7 Days: 128
Past 30 Days: 603
All Time: 81,947
