How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening)
  1. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Controller: step 1, image 1 of 1
    • Remove the battery case from the back of the controller
    • Remove all batteries
    • If you have a USB connected, remove it from the controller's USB port.
  2. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Cotton Balls: step 2, image 1 of 3 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Cotton Balls: step 2, image 2 of 3 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Cotton Balls: step 2, image 3 of 3
    • Apply a moderate amount of 70% Isopropyl Alcohol to the tip of a cotton ball
    • Keep your bottle of 70% Isopropyl Alcohol away from children and avoid touching your face and open wounds while using it.
  3. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Cleaning The Thumbsticks: step 3, image 1 of 2 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Cleaning The Thumbsticks: step 3, image 2 of 2
    • Thoroughly rub the cotton ball along the inside edges of the thumbstick to clean any internal debris.
  4. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): step 4, image 1 of 1
    • Allow the controller 1-2 minutes to dry.
  5. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): step 5, image 1 of 3 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): step 5, image 2 of 3 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): step 5, image 3 of 3
    • Repeat steps 2-4 three times
  6. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): step 6, image 1 of 1
    • Connect your wireless controller to your Xbox and test for stick drift.
    • If the problem persists, repeat step 5, or replace the potentiometers in the controller.
Finish Line
9 other people completed this guide.
Russell Repair Co.
2,000 Reputation
5 Guides authored
9 Comments
I feel stupid for not attempting to clean the thumb stick with alcohol sooner. thanks for the guide!
I didn't have any isopropyl alcohol, so I had to use Dr. Bob Goldstein's Nature's Protection Herbal Bug Spray 😅
it's 98% isopropyl alcohol, 1% cedarwood oil, and 1% peppermint oil
Adam - Reply
Using Isoprop to clean contacts is effective in a lot of things. Did it work for your controller?
Russell Repair Co. -
Me sinto estúpido por não ter tentado isso ainda kkk, obrigado.
Flávio R Freitas - Reply
I’m using cotton buds instead is that okay?
daniel arnfield - Reply
@danielarnfield assuming you mean Cotton Swabs, yes, it is okay. Some people actually prefer cotton swabs because of their precision.
Past 24 Hours: 93
Past 7 Days: 634
Past 30 Days: 3,378
All Time: 41,159
