How To Fix A Skipping LP Record
  1. How To Fix A Skipping LP Record, How To Fix A Skipping LP Record: step 1, image 1 of 1
    • Identify the problem area by playing the LP record on a turntable.
    • Note the damaged area.
  2. How To Fix A Skipping LP Record: step 2, image 1 of 2 How To Fix A Skipping LP Record: step 2, image 2 of 2
    • Lightly sand the problem area with the sand paper in a circular motion.
    • Sand lightly as possible to not permanently damage the LP.
  3. How To Fix A Skipping LP Record: step 3, image 1 of 2 How To Fix A Skipping LP Record: step 3, image 2 of 2
    • Brush off the record with a lint-free cloth or record-cleaning brush in a circular brushing motion.
    • Move the record around using the edge of the record and the palms of your hands (as to not touch the grooves).
  4. How To Fix A Skipping LP Record: step 4, image 1 of 3 How To Fix A Skipping LP Record: step 4, image 2 of 3 How To Fix A Skipping LP Record: step 4, image 3 of 3
    • Put about ¼ tsp. (1.25ml) of soap in the sink.
    • Fill the sink with about 3-4 inches of lukewarm water.
    • Make sure the sink is stopped so water will not drain. To active the soap, stir it around with your hand while filling up the sink.
  5. How To Fix A Skipping LP Record: step 5, image 1 of 2 How To Fix A Skipping LP Record: step 5, image 2 of 2
    • Gloves can be worn, but are not required
    • Put the record in the sink, submerging the record.
    • Turn the record over to ensure both sides of the record were submerged in the water.
  6. How To Fix A Skipping LP Record: step 6, image 1 of 2 How To Fix A Skipping LP Record: step 6, image 2 of 2
    • Make sure the whole surface of the record is wet.
    • Wet the lint free cloth and wash the LP
    • 10 to 15 times in the circular motion seems to work well.
  7. How To Fix A Skipping LP Record: step 7, image 1 of 2 How To Fix A Skipping LP Record: step 7, image 2 of 2
    • Allow the soapy water to drain from the sink.
    • Put the LP record in the sink and run cold water over the LP record.
    • Turn the record with the palms of your hand. After one side is clean, flip it over and do the other.
  8. How To Fix A Skipping LP Record: step 8, image 1 of 2 How To Fix A Skipping LP Record: step 8, image 2 of 2
    • Take a dry lint-free cloth and dry the LP record in a circular motion until wet spots are visibly gone.
  9. How To Fix A Skipping LP Record: step 9, image 1 of 1
    • Set the record on the drying rack vertically.
    • Make sure the record is completely dry before playing it again. The record will become damaged, if played while the record is still damp.
After the LP Record is completely dry, you will be able to play and enjoy the repaired record.
If the LP record is not fixed, this could indict a deep scratch that will need to be repaired by a professional.
2 other people completed this guide.
Robert Alexander
173 Reputation
1 Guide authored
Cal Poly, Team 10-7, Green Fall 2015 Member of Cal Poly, Team 10-7, Green Fall 2015
CPSU-GREEN-F15S10G7
3 Members
3 Guides authored
2 Comments
This is the worst advice I’ve ever read.
kalamazoometaldetecting - Reply
Did the method work though?!
DJ on Google -
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 15,202
