How to open and clean Keurig Coffee Maker
  1. How to open and clean Keurig Coffee Maker, How to open and clean Keurig Coffee Maker: step 1, image 1 of 3 How to open and clean Keurig Coffee Maker, How to open and clean Keurig Coffee Maker: step 1, image 2 of 3 How to open and clean Keurig Coffee Maker, How to open and clean Keurig Coffee Maker: step 1, image 3 of 3
    • Keurig K40 not brewing/dispensing 12oz
    • Open the Keurig all the way to remove the K-cup Holder
    • The K-cup holder simply pulls straight up. There might be a bit of resistance from some spring clips. The flaky debris is actually coffee from reusable K-cup filters.
  2. How to open and clean Keurig Coffee Maker: step 2, image 1 of 3 How to open and clean Keurig Coffee Maker: step 2, image 2 of 3 How to open and clean Keurig Coffee Maker: step 2, image 3 of 3
    • K-cup insert removed. Clean with hot water as needed.
    • On the bottom of the K-cup insert is a tapered needle that punctures the bottom of the K-cup. On the side of it is a small hole. Use a paper clip (or similar) and insert it in there to remove any scale, coffee grounds etc.
    • Next is to clean the top needle. It is trickier since it is somewhat hard to reach around the sides of the needle. There will be three holes around the needle. Open the Keurig all the way, and again use a paper clip (or similar).
  3. How to open and clean Keurig Coffee Maker: step 3, image 1 of 3 How to open and clean Keurig Coffee Maker: step 3, image 2 of 3 How to open and clean Keurig Coffee Maker: step 3, image 3 of 3
    • A hypodermic needle or similar can also be used to open up the water outlet
    • Next remove the water tank by simply lifting it up.
    • On the inside bottom of the tank is a simple check valve that allows the removal of the tank, then empty the tank.
  4. How to open and clean Keurig Coffee Maker: step 4, image 1 of 3 How to open and clean Keurig Coffee Maker: step 4, image 2 of 3 How to open and clean Keurig Coffee Maker: step 4, image 3 of 3
    • Top part of the check valve on the bottom. there is a fine screen that acts as a filter. Remove that by removing the three Phillips screws with a long #2 Phillips screwdriver. Clean the screen under running water with a brush. Reassemble after proper cleaning.
    • Next step is to remove the top cover to get to the water supply to the K-cup. Open the Keurig. remove two Phillips screws that hold it in place.
    • Lift the top cover up and forward to remove it.
  5. How to open and clean Keurig Coffee Maker: step 5, image 1 of 3 How to open and clean Keurig Coffee Maker: step 5, image 2 of 3 How to open and clean Keurig Coffee Maker: step 5, image 3 of 3
    • Water supply from the boiler to the K-cup needle is via a water hose through a check valve.
    • Remove the two small screws that hold the water line to the inlet
    • Unhook the water line from the connector above the K-cup needle. it is a simple press fit.
    • Next remove the tie straps. (You don't have to do this step) Just remove the other end of hose from pump. You might have to use a flat head screwdriver to lift up on end of hose while pulling up
  6. How to open and clean Keurig Coffee Maker: step 6, image 1 of 1
    • Test the check valve. Blowing air in it from the boiler side should cause it to open. Repeat that a couple of times to loosen any sediments etc. It will also help to run some hot water from the K-cup side into the check valve and shake it up. Once it is cleaned, replace the check valve and the tie straps. Reassemble the Keurig
104 other people completed this guide.
oldturkey03
782,216 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
537 Guides authored
90 Comments
Perfect - been looking all over for a solution besides trashing the unit.
Thank you for the step by step instructions!
kellywihlm - Reply
Awesome! didn't want to have to buy a new Keurig - worked like a charm!
cabate - Reply
awesome thank you kindley
racinnut2001 - Reply
Outstanding presentation. I've had my Keurig apart before. However, as I use well water and don't have the best filtration system, mine tends to clog frequently.
I will add however, that the case for, at least some Keurig coffee makers have clips holding the cover in place that can be rather difficult to release.
Bill Leach - Reply
I should add, excellent photography!
Bill Leach - Reply
Past 24 Hours: 103
Past 7 Days: 803
Past 30 Days: 3,813
All Time: 592,700
