Introduction
If your LED light strips are malfunctioning, then this guide may be what you need. Light strips malfunction when there is a faulty connection or wiring between two sections of the strips. These faulty connections can hinder the power flow and deactivate other working strips that are connected to the faulty strip.
The best way to fix this problem is to replace the faulty section with a new working strip. This guide will walk you through the steps of replacing your faulty light strips. You will learn how to identify which strip is in need of replacing, as well as how to remove that strip from the working strip. You will also see how to replace and reconnect the two working strips so that they are secured and working properly.
Reconnecting the strips will be completed by soldering the two working strips together by their corresponding connections.
If soldering is not a skill you are familiar with, you should first check out another guide on the basics of soldering. It is called “How to Solder and Desolder Connections.”
Before attempting this guide, remember to turn off the power to the strips that will be handled.
Find the spot where the lights stop working and where there are four connections labeled in descending order, "12V, R, G, B" with a scissor "cut here" marking and a copper colored backing.
A solder and soldering iron are fairly common and easy to acquire at a hardware store. Extra length of lights may be left over from initial use, use these first before buying more in order to lower costs; be sure you only cut the lights for repair where these 4 pads are they are likely marked by a dotted line across them, this is also where you'll solder them together. In order to put the lights back where they originally were, some form of an adhesive agent may need to be utilized. On the rear side of connection spot you can glue a small piece of cardboard to hold them together.
10 other people completed this guide.
7 Comments
I dont know why this tutorial is rated as difficult, it really isnt.
Thet step 4 was just weird
Click here to read the complete article if you want to know How to Fix LED Lights That Are Different Colors.
Huh, I needed this exact guide. That's nuts.
