How to Fix a Loose Light Socket on a Lamp Model L37721
  1. How to Fix a Loose Light Socket on a Lamp Model L37721, How to Fix a Loose Light Socket on a Lamp Model L37721: step 1, image 1 of 1
    • Unplug the lamp from the electrical socket.
    • Ensure that there is no electrical charge in the lamp by turning the lamp on and off.
  2. How to Fix a Loose Light Socket on a Lamp Model L37721: step 2, image 1 of 3 How to Fix a Loose Light Socket on a Lamp Model L37721: step 2, image 2 of 3 How to Fix a Loose Light Socket on a Lamp Model L37721: step 2, image 3 of 3
    • Turn the lamp shade knob in a counterclockwise direction to remove it.
    • Lift the lampshade to remove it.
  3. How to Fix a Loose Light Socket on a Lamp Model L37721: step 3, image 1 of 2 How to Fix a Loose Light Socket on a Lamp Model L37721: step 3, image 2 of 2
    • Turn the light bulb in a counterclockwise direction to remove it.
  4. How to Fix a Loose Light Socket on a Lamp Model L37721: step 4, image 1 of 2 How to Fix a Loose Light Socket on a Lamp Model L37721: step 4, image 2 of 2
    • Lift the tabs up from the base.
    • Squeeze the lamp shade posts inward to release them.
  5. How to Fix a Loose Light Socket on a Lamp Model L37721: step 5, image 1 of 2 How to Fix a Loose Light Socket on a Lamp Model L37721: step 5, image 2 of 2
    • Place the flat side of the screwdriver against the flat side of the nut inside of the base.
  6. How to Fix a Loose Light Socket on a Lamp Model L37721: step 6, image 1 of 2 How to Fix a Loose Light Socket on a Lamp Model L37721: step 6, image 2 of 2
    • While placing pressure against the nut, grip the light socket and turn it in a clockwise direction until it is tight against the base.
Robert McNabb
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 63
All Time: 5,564
