How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering
  1. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering, How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 1, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering, How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 1, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering, How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 1, image 3 of 3
    • Remove the four 6.0 mm screws on the back shell of the PS4 controller using the Phillips #00 screwdriver.
  2. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 2, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 2, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 2, image 3 of 3
    • Detach the back shell from the rest of the body by pulling the front shell and back shell apart simultaneously.
  3. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 3, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 3, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 3, image 3 of 3
    • Be very gentle when completely detaching the back shell because the blue ribbon could be damaged.
    • Lightly pull the blue ribbon to separate the back shell and the front shell.
    • The front shell housing the circuit board will be dismantled further.
  4. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 4, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 4, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 4, image 3 of 3
    • Remove the battery connector from the motherboard by pressing the two sides and pulling on the connecter in an upwards direction.
    • Be careful not to rip the black or red cables from the connector while removing the cables.
  5. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 5, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 5, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 5, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the single 6.0 mm screw attached to the circuit board.
    • Once the screw is removed the battery holder is loosened, which allows for the holder to be removed by pulling it upwards.
    • Remove the battery cable.
  6. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 6, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 6, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 6, image 3 of 3
    • Detach the cable from the circuit board by pulling upwards.
    • Pull the circuit board away from the front shell so it is completely detached from all other parts.
  7. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 7, image 1 of 2 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 7, image 2 of 2
    • Remove the left joystick by pulling it upwards until it pops off.
  8. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 8, image 1 of 2 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 8, image 2 of 2
    • On each of the green chambers, there is a gap that separates the sliver body and the green chambers.
    • Use the flathead screwdriver to pry open the green chambers by sticking the tip of the flathead screwdriver in between the gap and pushing inwards.
    • Pry open very gently so the green chambers do not snap/break away from the circuit board.
  9. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 9, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 9, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 9, image 3 of 3
    • Once the chambers are open, use tweezers to grab and remove the white disk from each of the chambers.
    • Take a Q-tip and dip it in some 90% isopropyl alcohol.
    • Use the soaked Q-tip to clean the chambers thoroughly.
    • Let the green chambers dry for about 5-10 minutes before resuming the reassembly.
  10. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 10, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 10, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 10, image 3 of 3
    • Place the two white disks back into the green chamber using the tweezers.
    • Close both chambers by pressing hard towards the sliver box until they click in.
  11. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 11, image 1 of 1
    • Take the left joystick and put it back on until the click is heard which confirms that the joystick is firmly held on.
  12. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 12, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 12, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 12, image 3 of 3
    • Loop the cable connecter into the circuit board hole from the front shell to attach both parts.
    • I personally used tweezers to get the cable connecter from the front shell to the circuit board.
    • Place the connecter into its socket and press downwards to connect it back.
  13. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 13, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 13, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 13, image 3 of 3
    • Take the battery holder and place the pegs into the hole for the proper alignment.
    • Replace the 6.0 mm screw onto the battery holder back using the Phillips #00 screwdriver so the battery holder can be held firmly in place with the circuit board.
  14. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 14, image 1 of 2 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 14, image 2 of 2
    • Place the battery into the holder.
    • Connect the red and black wire of the battery into the socket by pressing downwards.
  15. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 15, image 1 of 2 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 15, image 2 of 2
    • Place the ribbon attached to the back shell on the circuit board and press down so both compartments get attached.
  16. How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 16, image 1 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 16, image 2 of 3 How to Fix Left Joystick Drift on a DualShock PS4 Controller Without Soldering: step 16, image 3 of 3
    • Snap the front shell and back shell together.
    • Screw the four 6.0 mm Phillips screws on the back shell screw holders using the Phillips #00 screwdriver.
    • Your controller should be all ready!
Finish Line
61 other people completed this guide.
Anubhab Rahman
1,999 Reputation
1 Guide authored
9 Comments
does this work with the right joystick too?
long tran - Reply
Yes! Both sticks seems to be identical. Did my right one and it fixed the drift.
raltamimi0001 -
i fix my brothers ds4 with your tutorial. Thank you very much.
Bryan Avila - Reply
Thank you so much for this amazingly well made guide. I just fixed my PS4 controller and it surprised me how well it works, absolutely no drift whatsoever. I should note that i’ve done the same steps on the right stick as it’s the one broken for me.
raltamimi0001 - Reply
I just followed the guide and the drift problem is gone! A really throughout guide with all the details and warnings. Thank you for this.
Diego Costa - Reply
Past 24 Hours: 39
Past 7 Days: 389
Past 30 Days: 1,701
All Time: 61,003
