Hover-1 XLS Back Seat Light Replacement
  1. Hover-1 XLS Back Seat Light Replacement, Back Seat Light: step 1, image 1 of 2 Hover-1 XLS Back Seat Light Replacement, Back Seat Light: step 1, image 2 of 2
    • Remove the seat by removing the six 16mm screws with a Phillips #2 screwdriver.
    • Remember that the seat is still connected by the wiring once you unscrew it. Pulling too hard can damage the connector.
  2. Hover-1 XLS Back Seat Light Replacement: step 2, image 1 of 3 Hover-1 XLS Back Seat Light Replacement: step 2, image 2 of 3 Hover-1 XLS Back Seat Light Replacement: step 2, image 3 of 3
    • Disconnect the wires by pushing the levers on either side of the connector and on top.
    • Remove the seat from the bike.
  3. Hover-1 XLS Back Seat Light Replacement: step 3, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the four 10mm screws on the bottom of the back seat.
  4. Hover-1 XLS Back Seat Light Replacement: step 4, image 1 of 2 Hover-1 XLS Back Seat Light Replacement: step 4, image 2 of 2
    • Pull the light from behind the bottom of the seat frame. Pull the wiring all the way through.
Christian Roberts
248 Reputation
1 Guide authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 337
