Honeywell HY-204 Rotation Motor Replacement
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: step 1, image 1 of 1
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: step 2, image 1 of 1
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: step 3, image 1 of 2 Honeywell HY-204 Rotation Motor Replacement: step 3, image 2 of 2
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: step 4, image 1 of 1
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: step 5, image 1 of 1
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
Armando Jacob Espinoza
500 Reputation
3 Guides authored
Cal Poly, Team 10-40, Amido Fall 2014 Member of Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,640
