Homemade Toaster Repair Tool for Securing Nichrome Screws on reassembly (Model 2)
  1. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2), Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 1, image 1 of 2 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2), Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 1, image 2 of 2
    • Model Two, of the two I've built. Homemade tools for holding screws to easily insert them into the Mica sheet, when repairing broken Nichrome wire thread in toasters.
  2. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 2, image 1 of 2 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 2, image 2 of 2
    • Materials Used; in my case I had a thin 4 mm diameter aluminum tube, a thin bicycle brake cable and a small electrician's power strip, the items appearing in the photo are ones I used in Model number one.
    • Model No. 1
  3. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 3, image 1 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 3, image 2 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 3, image 3 of 3
    • Cut the aluminum tube with a tube cutter, to approximately 20 cm. in length.
  4. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 4, image 1 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 4, image 2 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 4, image 3 of 3
    • File a notch at the end of the tube giving it an 'L' shape so it adequately supports the screw to be secured.
  5. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 5, image 1 of 2 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 5, image 2 of 2
    • Screw supported on the aluminum tube.
  6. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 6, image 1 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 6, image 2 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 6, image 3 of 3
    • Bicycle brake cable inserted into the tube.
  7. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 7, image 1 of 2 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 7, image 2 of 2
    • Electrician's mini power strips; I used a small one to hold the cable.
  8. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 8, image 1 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 8, image 2 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 8, image 3 of 3
    • Insert the cable into the strip, then secure it with the two screws. We leave enough space in the loop to fit three fingers.
  9. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 9, image 1 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 9, image 2 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 9, image 3 of 3
    • Photos of the end of the loop, whereby we hold the screw.
  10. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 10, image 1 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 10, image 2 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 10, image 3 of 3
    • Example; holding the tool.
  11. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 11, image 1 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 11, image 2 of 3 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 11, image 3 of 3
    • Application of a drop of Vaseline to the end of the tube makes the steel cable slide more easily inside the tube. Thus easier to pull and release the screw.
  12. Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 12, image 1 of 2 Homemade Toaster Repair Tool for  Securing Nichrome Screws  on reassembly (Model 2): step 12, image 2 of 2
    • Photos of the completed tool.
Finish Line
Special thanks to these translators:
es en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
88,360 Reputation
301 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 108
