Hipstreet Titan 2 HD Battery Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
99
All Time:
4,857
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Users must disassemble the front cover to replace the battery. A replacement battery will be needed. This is a difficult process for users who do not have experience with soldering connections.
Tools
    1. Hipstreet Titan 2 HD Battery Replacement, Rear Case: step 1, image 1 of 1
      • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
      • The screws are located on the bottom face of the device, near the power and volume controls.
      Ask FixBot
    2. Hipstreet Titan 2 HD Battery Replacement: step 2, image 1 of 1
      • Place the small suction cup on your screen.
      • Moisturize the bottom of the suction cup to ensure a proper seal.
      • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
      Ask FixBot
    3. Hipstreet Titan 2 HD Battery Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
      • Grasp the small suction cup.
      Ask FixBot
    4. Hipstreet Titan 2 HD Battery Replacement: step 4, image 1 of 2 Hipstreet Titan 2 HD Battery Replacement: step 4, image 2 of 2
      • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
      • Pull upward on the small suction cup handle while sliding the opening tool.
      • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
      Ask FixBot
    5. Hipstreet Titan 2 HD Battery Replacement: step 5, image 1 of 2 Hipstreet Titan 2 HD Battery Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to remove the speaker from the rear cover.
      • The speaker is held in place with adhesive and is easily removed.
      • Do not pull on the speaker wires. This could damage the soldering connections.
      Ask FixBot
    6. Hipstreet Titan 2 HD Battery Replacement: step 6, image 1 of 1
      • Once the speaker is disconnected, the cover removal is complete.
      Ask FixBot
    1. Hipstreet Titan 2 HD Battery Replacement, Battery: step 7, image 1 of 2 Hipstreet Titan 2 HD Battery Replacement, Battery: step 7, image 2 of 2
      • Remove the black placement tape from the battery.
      • Find the two battery solder connections on the circuit board.
      Ask FixBot
    2. Hipstreet Titan 2 HD Battery Replacement: step 8, image 1 of 1
      • Remove the red and black battery wires from the circuit board with the solder removal tool.
      Ask FixBot
    3. Hipstreet Titan 2 HD Battery Replacement: step 9, image 1 of 1
      • Solder the new battery wire connectors to the circuit board.
      • The battery wires must be installed with the red wire on the left and black wire on the right.
      Ask FixBot
Jeffrey
766 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 99
All Time: 4,857
