Danger
Potentially Dangerous
Injury may result if this procedure is not followed properly. Use caution and follow all warnings.
Danger
Introduction
I will demonstrate how to replace the non-replacable battery in the Hipstreet Phoenix. Be careful, as it may be swollen.
Parts
No parts required.
  1. OK. So here we go. This guide will demonstrate how to replace the battery in the device shown. And sorry for the bad image quality, my camera lens is dirty. OK. So here we go. This guide will demonstrate how to replace the battery in the device shown. And sorry for the bad image quality, my camera lens is dirty.
    • OK. So here we go. This guide will demonstrate how to replace the battery in the device shown. And sorry for the bad image quality, my camera lens is dirty.
    • If you don't, you could have a lithium ion fire, and that's no good.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  3. OK. Mine suffered this, and it still works. That's for the record. You will need a eyeglass screwdriver, or if the battery already puffed up, you don't need it or then you have a step 2 case, and nobody wants that.
    • OK. Mine suffered this, and it still works. That's for the record. You will need a eyeglass screwdriver, or if the battery already puffed up, you don't need it or then you have a step 2 case, and nobody wants that.
    • Be VERY VERY VERY VERY VERY careful. You now have to remove the battery with scissors. Cut the leads. I don't have a picture, so imagine step 3's image having a battery, and cut the 2 leads with scissors.
    • On mine, I used one of the pads used to secure the battery to hold the loose leads. You now have to reseal the case; use that screwdriver. If you did already; and it's currently on your desk being a 40 dollar paperweight, you are done! Now go hook it up to a computer and transfer music files! Note: you need to be careful, if your (look at line 2)
    • (continued from line 1) cable's tip is bent, you have to be careful.
You are done fixing it! Be happy! (Note: you need a cell phone charger tube battery to use it as a portable)
Kaleb White
113 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 393
