Remove the battery by locating the battery compartment beneath the drone. Slide the latch back and flip it open.
Disconnect the battery terminal as shown in Blue.
Unscrew all four blade screws by using a small Phillips screw driver and remove the blade.
Remember to store all screws and components neatly. See second picture
Remove the legs by screwing the 3 screws out as indicated in the first picture.
Remove the legs and screws and store it neatly.
Simply lift the gear and its axle.
Note that when removing the small bearings (Red) can fall out. There are two bearings per axle, one on the top (Red arrow) and one on the bottom.
After removing the blades/props, legs and gears, the drone should look like this.
Tip: When storing the screws, you can tape them in masking tape and the label the tape with a pen to remember which screws comes where.
Remove both screws on all four arms by using a small Philips screwdriver.
Next. Remove the three screws on each arm's end by using a small Philips screwdriver.
Remember to organize your screws.
After separating the top and bottom half of the drone locate the antenna as shown the second picture.
Carefully use your tweezers and lift the the antenna out by wedging the tweezers underneath. (See picture)
After the removing of the antenna it should look like this(The third picture)
At this stage you can access most of the drone and don't need further disassembly.
Disconnect the WIFI PCB(Blue) from the main PCB(Green) by disconnecting the ribbon cable.
Use the tweezers and grip the white plastic end of the cable. Slowly pull and wiggle the two ports from each other.
To access the camera unit the main PCB needs to be disconnected.
First, Pull the battery terminal out through the hole between the WIFI PCB and plastic side of the drone.
Next, Remove the four screws on the main PCB as in the second picture.
Now you can fully access the WIFI PCB and camera unit.
Two of my drone's arms were broken and therefore I could flip over the whole main PCB.
To disconnect the cable between the camera and WIFI PCB follow the next two steps.
Use the sharp point of the tweeter and gently move the black plastic wedge back to loosen the cable.
Pull the cable gently with your fingers and it should easily come out.
Unscrew the last two screws of the camera unit.
The camera should be loose now and can be taken out of the drone.
And there you go! Well done!
I hope that this Guide was helpful.
