HTC One M9 Motherboard Replacement
  1. HTC One M9 Motherboard Replacement, MicroSD Card: step 1, image 1 of 3 HTC One M9 Motherboard Replacement, MicroSD Card: step 1, image 2 of 3 HTC One M9 Motherboard Replacement, MicroSD Card: step 1, image 3 of 3
    • The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
    • Then press the tool or paperclip to eject the microSD card tray.
    • This may require a significant amount of force.
    • When reinserting the microSD card, ensure that it is in the correct orientation to the tray. The electrical connectors should be inserted first, with the microSD card face up.
    • It is normal for the microSD to sit imperfectly in the tray. The microSD card is easy to reposition within the tray.
  2. HTC One M9 Motherboard Replacement, SIM Card: step 2, image 1 of 3 HTC One M9 Motherboard Replacement, SIM Card: step 2, image 2 of 3 HTC One M9 Motherboard Replacement, SIM Card: step 2, image 3 of 3
    • Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
    • Press to eject the tray.
    • When reinserting the SIM card, ensure that its contacts are facing to the rear side. The tapered corner of the SIM card has to point to the outer bottom corner of the tray.
  3. HTC One M9 Motherboard Replacement, Rear Case: step 3, image 1 of 3 HTC One M9 Motherboard Replacement, Rear Case: step 3, image 2 of 3 HTC One M9 Motherboard Replacement, Rear Case: step 3, image 3 of 3
    • Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
    • Remove the two 4 mm T5 Torx screws on the top of the case.
  4. HTC One M9 Motherboard Replacement: step 4, image 1 of 3 HTC One M9 Motherboard Replacement: step 4, image 2 of 3 HTC One M9 Motherboard Replacement: step 4, image 3 of 3
    • Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly.
    • The SIM card tray and Micro SD card tray must be removed before the back cover can be removed.
    • Be careful around the power and volume buttons, as they are fairly delicate.
    • Be careful when separating the body from the display assembly, as the rear-facing camera may be stuck to the body with adhesive.
  5. HTC One M9 Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Use a pair of tweezers to disconnect the blue and white antenna cables. Note that some models of this phone will have only one antenna cable at this location.
  6. HTC One M9 Motherboard Replacement: step 6, image 1 of 1
    • Remove the two 1.5 mm Phillips screws securing the battery connector to the motherboard.
    • Use a spudger to pry the battery connector from its socket, being careful to apply pressure only to the connector and not to the socket.
  7. HTC One M9 Motherboard Replacement: step 7, image 1 of 1
    • Peel back the Kapton tape from the ZIF connector, then use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
  8. HTC One M9 Motherboard Replacement: step 8, image 1 of 1
  9. HTC One M9 Motherboard Replacement: step 9, image 1 of 3 HTC One M9 Motherboard Replacement: step 9, image 2 of 3 HTC One M9 Motherboard Replacement: step 9, image 3 of 3
    • With the tweezers, carefully lift up on the tape covering the electrical strip shown in the picture.
    • Be careful with the tape as it can tear easily. You will have better luck if you pull back the orange Kapton tape rather than the silver electrical strip.
    • Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
  10. HTC One M9 Motherboard Replacement: step 10, image 1 of 3 HTC One M9 Motherboard Replacement: step 10, image 2 of 3 HTC One M9 Motherboard Replacement: step 10, image 3 of 3
    • Peel back the Kapton tape from the remaining three ZIF connectors, then use your fingernail or a spudger to lift the hinged retainer clips on the ZIF connectors and slide the cables out from each.
    • The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
  11. HTC One M9 Motherboard Replacement: step 11, image 1 of 3 HTC One M9 Motherboard Replacement: step 11, image 2 of 3 HTC One M9 Motherboard Replacement: step 11, image 3 of 3
    • Remove the dual LED flash cover. This is held on with a small amount of adhesive. Be careful here: the flash cover may be glued to the antenna cable(s) below. Apply a small amount of heat here to soften the adhesive before removal.
    • Use a pair of tweezers to disconnect the two antenna cables near the camera. Note that some models of this phone will have only one antenna cable at this location.
    • Use a pair of tweezers to disconnect the antenna cable near the bottom of the phone.
  12. HTC One M9 Motherboard Replacement: step 12, image 1 of 1
    • Remove the three 4mm T5 Torx screws securing the motherboard.
  13. HTC One M9 Motherboard Replacement: step 13, image 1 of 2 HTC One M9 Motherboard Replacement: step 13, image 2 of 2
    • Use a pair of tweezers to gently lift the vibrator out of its crevace. It is held in only with friction, no adhesive or screws. Be careful when lifting to avoid damaging the wires connecting it to the motherboard.
    • Use a plastic opening tool or a spudger to gently pry the motherboard out of the case. lift first from the top (near the camera).
    • The motherboard is secured with adhesive at the bottom (on the speaker assembly) so you may need to use an iOpener or heat gun to loosen the adhesive. Refer to the iOpener guide for info on this.
Rodolfo Meave
1,434 Reputation
2 Guides authored
Cal Poly, Team 6-16, Maness Spring 2015 Member of Cal Poly, Team 6-16, Maness Spring 2015
CPSU-MANESS-S15S6G16
4 Members
16 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 24
All Time: 11,111
