HTC Inspire 4G Display Assembly Replacement
  1. HTC Inspire 4G Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 HTC Inspire 4G Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 HTC Inspire 4G Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
    • Remove battery cover using a plastic opening tool or finger nail.
    • Slide opening tool to release clasps and remove battery cover.
  2. HTC Inspire 4G Display Assembly Replacement: step 2, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 2, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 2, image 3 of 3
    • With the cover removed, the battery will fall freely with a gentle shake.
  3. HTC Inspire 4G Display Assembly Replacement: step 3, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 3, image 2 of 2
    • Remove SIM card cover by simultaneously squeezing cover and pulling it off of the phone.
  4. HTC Inspire 4G Display Assembly Replacement: step 4, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 4, image 2 of 2
    • Slide SIM card out.
  5. HTC Inspire 4G Display Assembly Replacement: step 5, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 5, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 5, image 3 of 3
    • Remove Micro SD card by pushing it in to the phone. Spring-loaded clasp will release the card.
  6. HTC Inspire 4G Display Assembly Replacement: step 6, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 6, image 2 of 2
    • Use a curved metal spudger to remove GPS cover.
    • Probe underside of GPS cover until you can force a small opening between GPS cover and back cover of phone.
  7. HTC Inspire 4G Display Assembly Replacement: step 7, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 7, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 7, image 3 of 3
    • Insert plastic opening tool into gap between GPS cover and back cover of phone. Slide tool along GPS cover and pry the piece off.
  8. HTC Inspire 4G Display Assembly Replacement: step 8, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 8, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 8, image 3 of 3
    • Remove "VOID" sticker from screw.
    • If your phone has a warranty, removing "VOID" sticker will void your warranty.
  9. HTC Inspire 4G Display Assembly Replacement: step 9, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 9, image 2 of 2
    • Remove four 2.2mm T5 torx screws.
    • Remove one 4.5mm T5 torx screw.
  10. HTC Inspire 4G Display Assembly Replacement: step 10, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 10, image 2 of 2
    • Remove display cable shield.
    • Insert probing tool into screw hole and pull shield.
    • Be careful! This piece is made of thin, springy metal and will fly across the room if you remove it too forcefully.
  11. HTC Inspire 4G Display Assembly Replacement: step 11, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 11, image 2 of 2
    • Peel off manufacturer's information sticker.
  12. HTC Inspire 4G Display Assembly Replacement: step 12, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 12, image 2 of 2
    • Lift volume button assembly out of the back case.
    • Work slowly! Initially, you must lever the assembly from the ribbon cable attaching it to the upper logic board. The cable is delicate.
  13. HTC Inspire 4G Display Assembly Replacement: step 13, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 13, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 13, image 3 of 3
    • Push up on the back cover, wiggling cover back and forth, until it slides off.
  14. HTC Inspire 4G Display Assembly Replacement: step 14, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 14, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 14, image 3 of 3
    • Remove "VOID" sticker.
    • If your phone has a warranty, removing the "VOID" sticker will void your warranty.
    • Remove three 2.4mm T5 torx screws.
  15. HTC Inspire 4G Display Assembly Replacement: step 15, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 15, image 2 of 2
    • Apply pressure to the bottom of the plastic logic board shield and it will pop right off.
  16. HTC Inspire 4G Display Assembly Replacement: step 16, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 16, image 2 of 2
    • Remove rubber spacer.
  17. HTC Inspire 4G Display Assembly Replacement: step 17, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 17, image 2 of 2
    • Peel off Mylar tape.
  18. HTC Inspire 4G Display Assembly Replacement: step 18, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 18, image 2 of 2
    • Peel off electrical tape.
  19. HTC Inspire 4G Display Assembly Replacement: step 19, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 19, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 19, image 3 of 3
    • Pry display assembly connector off of lower logic board.
  20. HTC Inspire 4G Display Assembly Replacement: step 20, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 20, image 2 of 2
    • Remove metal bracket.
  21. HTC Inspire 4G Display Assembly Replacement: step 21, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 21, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 21, image 3 of 3
    • Remove speaker.
    • During reassembly, be careful with the spring connectors on the reverse side of the speaker unit. They are bent easily.
    • This rubber spacer is held on by a weak adhesive. Be careful with this during reassembly, as it may catch and crumple as you put the back panel back the phone.
  22. HTC Inspire 4G Display Assembly Replacement: step 22, image 1 of 1
    • Remove one 1.5mm #00 Phillips screw.
    • Remove two 2.5mm T5 torx screws.
  23. HTC Inspire 4G Display Assembly Replacement: step 23, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 23, image 2 of 2
    • Remove earpiece speaker connector.
  24. HTC Inspire 4G Display Assembly Replacement: step 24, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 24, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 24, image 3 of 3
    • Pry off Bluetooth coaxial cable connector.
    • Unwind Bluetooth coaxial cable from plastic camera shield.
  25. HTC Inspire 4G Display Assembly Replacement: step 25, image 1 of 3 HTC Inspire 4G Display Assembly Replacement: step 25, image 2 of 3 HTC Inspire 4G Display Assembly Replacement: step 25, image 3 of 3
    • Pry off plastic camera shield.
  26. HTC Inspire 4G Display Assembly Replacement: step 26, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 26, image 2 of 2
    • Heat black Mylar shield for easier removal.
    • As you can see, we attempted to peel off the Mylar shield before heating it. It required more force than we were comfortable with, so we turned up the heat!
    • Peel off Mylar shield.
  27. HTC Inspire 4G Display Assembly Replacement: step 27, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 27, image 2 of 2
    • Gently separate upper logic board from mid chassis. The upper logic board is held to the mid chassis by copious amounts of strong adhesive.
  28. HTC Inspire 4G Display Assembly Replacement: step 28, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 28, image 2 of 2
    • Gently separate lower logic board from mid chassis. The lower logic board is held to the mid chassis by copious amounts of strong adhesive.
  29. HTC Inspire 4G Display Assembly Replacement: step 29, image 1 of 1
    • Once the adhesive-laden logic boards are separated from the mid chassis, the entire assembly easily comes off.
    • Be careful when handing the logic board assembly. We could have separated out each part, but decided it was a waste of time. The cost of cutting this corner is extra care when handling the logic board assembly.
  30. HTC Inspire 4G Display Assembly Replacement: step 30, image 1 of 2 HTC Inspire 4G Display Assembly Replacement: step 30, image 2 of 2
    • Blast the front panel with heat and pry between the display assembly and front panel bezel, working one or several guitar picks around the display assembly.
    • Once the display assembly is loosened from the front panel, it will fall away.
    • The front glass came off easily, but the digitizer was much more difficult to remove. The adhesive holding together the display assembly is much weaker than the adhesive holding the display assembly to the front panel.
    • While creating this guide, I utterly destroyed the front panel bezel and digitizer. Replacing the display assembly was a breeze--but removing the digitizer required nearly a dozen reheats of the front panel. To replace the bezel, you will need a new "mid chassis" (that's the front panel piece the digitizer is so powerfully glued to).
Jeff Snyder
8,799 Reputation
4 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,732 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 5,345
