HP iPAQ H3850 Speaker Replacement
  1. HP iPAQ H3850 Speaker Replacement, Speaker: step 1, image 1 of 1
    • To start the disassembly of iPAQ speaker shown by picture, you must place speaker on a flat surface with the screen laying down.
  2. HP iPAQ H3850 Speaker Replacement: step 2, image 1 of 1
    • To begin, remove the four screw located on iPAQ speaker back cover.
  3. HP iPAQ H3850 Speaker Replacement: step 3, image 1 of 1
    • You must carefully remove the back cover using a plastic opening tool against the grooves along the sides of the iPAQ speaker.
  4. HP iPAQ H3850 Speaker Replacement: step 4, image 1 of 1
    • Using the plastic opening tool, carefully detach the yellow ribbon from the connector pins to separate the iPAQ speaker into two halves. (This step isn't necessary for speaker removal it will just make the process a lot easier.)
  5. HP iPAQ H3850 Speaker Replacement: step 5, image 1 of 1
    • Remove ribbon cable connected to iPAQ speaker logic board by pulling plastic clips on both sides towards top of iPAQ speaker.
    • Use plastic opening tool to carefully pull brown ribbon cable from connector.
  6. HP iPAQ H3850 Speaker Replacement: step 6, image 1 of 3 HP iPAQ H3850 Speaker Replacement: step 6, image 2 of 3 HP iPAQ H3850 Speaker Replacement: step 6, image 3 of 3
    • Use plastic opening tool to carefully remove display logic board from housing.
    • Unplug connector from the opposite end of the display logic board.
    • Completely remove component.
  7. HP iPAQ H3850 Speaker Replacement: step 7, image 1 of 1
    • Flip up black plastic clip on large ribbon cable connector located towards center of mother board.
    • Use plastic opening tool to carefully remove ribbon cable from connector.
  8. HP iPAQ H3850 Speaker Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Gently pry clear/grey ribbon cable in the bottom corner of the device out of connector with plastic opening tool.
    • Use hands or tweezers to remove if necessary
  9. HP iPAQ H3850 Speaker Replacement: step 9, image 1 of 1
    • Use hands to gently unplug speaker and microphone connectors from mother board.
  10. HP iPAQ H3850 Speaker Replacement: step 10, image 1 of 1
    • Remove four small screws from each corner of the motherboard using phillips head screwdriver.
    • Use your hands/plastic opening tool to carefully lift the mother board out of housing.
    • Place the motherboard to the side.
  11. HP iPAQ H3850 Speaker Replacement: step 11, image 1 of 3 HP iPAQ H3850 Speaker Replacement: step 11, image 2 of 3 HP iPAQ H3850 Speaker Replacement: step 11, image 3 of 3
    • At the top of the iPAQ remove the screws holding down the speaker and housing.
    • When the screws are out pry out speaker along with the housing.
    • Lay down the speaker and housing with the housing on the bottom side and pry out the speaker with the plastic opening tool.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 62
All Time: 545
