Introduction
Does your computer feel warmer than usual? Here are some reasons why your laptop might be running hot. If you determine that you need to replace the fan or heatsink assembly, follow this guide!
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
Slide the right lever firmly to the right.
Slide the cover towards yourself to remove it.
Flip the laptop over so the keyboard is visible.
Insert the spudger under the left side of the keyboard.
Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
Carefully slide the keyboard up toward the screen and out of the case.
Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose.
Disconnect the black ribbon by pulling the blue tab hanging off of it.
Repeat with the white ribbon.
Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
Once the drive is protruding from the side of the computer, pull it the rest of the way out.
Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
Unscrew two 3mm screws from the hard drive bay with a Phillips #0 screwdriver.
Rotate the laptop so the battery compartment is in front of you.
Remove the four 4 mm screws under the battery with a T8 Torx screwdriver.
Use a spudger to lift the edges of the connector up so the white ribbon can slide out.
Pull the ribbons out by the blue plastic tab on the cable at each connector site.
Start at the front of the latop and run a plastic spudger between the top cover and the case to undo the clips holding it together
Angle the top cover so you can see the white ribbons shown in the picture.
Carefully slide the top cover toward you to expose the white ribbon connectors.
Use a spudger to lift the connectors and slide out both ribbons.
Gently lift the fan and heatsink assembly straight up and out so you do not smear the thermal paste.
