You're viewing a previously published version of this guide.  View latest version
Older Newer
Parts
No parts specified.
  1. Use your nail or a spudger to pry the back cover off of the device.
    • Use your nail or a spudger to pry the back cover off of the device.
  2. Slide your finger around the rest of the back cover, lifting it completely off of the device.
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. Remove ten Phillips #00 screws from the inside cover.
    • Remove ten Phillips #00 screws from the inside cover.
  4. Pry up the inside cover the same way as in the first step.
    • Pry up the inside cover the same way as in the first step.
Nick Miller
669 Reputation
6 Guides authored
Cal Poly, Team 34-14, Maness Spring 2016 Member of Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 452
