HP Stream 11-r020nr Charging Port Replacement
  1. HP Stream 11-r020nr Charging Port Replacement, Keyboard Panel: step 1, image 1 of 2 HP Stream 11-r020nr Charging Port Replacement, Keyboard Panel: step 1, image 2 of 2
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr Charging Port Replacement: step 2, image 1 of 1
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr Charging Port Replacement: step 3, image 1 of 2 HP Stream 11-r020nr Charging Port Replacement: step 3, image 2 of 2
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr Charging Port Replacement: step 4, image 1 of 2 HP Stream 11-r020nr Charging Port Replacement: step 4, image 2 of 2
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr Charging Port Replacement: step 5, image 1 of 2 HP Stream 11-r020nr Charging Port Replacement: step 5, image 2 of 2
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr Charging Port Replacement: step 6, image 1 of 2 HP Stream 11-r020nr Charging Port Replacement: step 6, image 2 of 2
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr Charging Port Replacement: step 7, image 1 of 1
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
  8. HP Stream 11-r020nr Charging Port Replacement, Charging Port: step 8, image 1 of 1
    • Pull the power cable away with your fingers.
  9. HP Stream 11-r020nr Charging Port Replacement: step 9, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the 4 mm screw.
  10. HP Stream 11-r020nr Charging Port Replacement: step 10, image 1 of 1
    • Lift and remove the charging port from the device.
2 Comments
my hp stream is not charging will be the problem
Nenwarang - Reply
Hp stream 14 is not charging pls help me out battery is dropping down instead of going up
Nenwarang - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,521
