Introduction
If your HP Stream 11-d010nr laptop is showing signs of a faulty battery, such as not holding a charge or not turning on at all, its battery may need to be replaced. This guide will show you the steps necessary to do so.
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
Carefully disconnect the three ribbon cables.
Remove any tape holding the battery connector in place.
Using your fingers, carefully unplug the battery.
Remove the four 3mm #000 Phillips screws holding the battery in place.
Carefully lift the battery out of the laptop.
