Introduction
A user will effectively understand how to remove a hard drive from the device.
Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
Gently wedge the plastic opening tool in between where the display and back panel meet.
Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
Rotate the device so that the side is facing up and repeat the previous step for the sides.
Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
Locate the hard drive. (The hard drive is located in the center of the device)
Locate the connection of the hard drive to the device.
Gently grasp the connector cord and pull horizontally to the right. (Very little force is needed to disconnect the cord).
The hard drive is no longer connected to the device. Lift the hard drive up vertically and set aside.
The hard drive removal is completed.
Hello, I liked the tutorial a lot because I solved a problem, but I wanted to ask you a question ... where the RAM memories are located in this model of equipment.
Thank you.
Atte. Jose Esquivel.
4 other people completed this guide.
One Comment
Is it possible to change the Wd5000m21k disk for a Wd5000m22k?
