Introduction
If your HP Spectre x360 13-ac023dx laptop will not boot up after troubleshooting possibles errors, use this motherboard replacement guide.
Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
Then, carefully lift the battery off with the iFixit opening tool.
Need to provide a direction in step #1 about removing the rubber pads and accessing the two screws at the bottom.
Second that. What's the best way to remove the feet?
Ensure that all other components which were previously removed are not longer attached.
