HP Spectre x360 13-ac023dx Display Replacement
  1. HP Spectre x360 13-ac023dx Display Replacement, Battery: step 1, image 1 of 2 HP Spectre x360 13-ac023dx Display Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Display Replacement: step 2, image 1 of 3 HP Spectre x360 13-ac023dx Display Replacement: step 2, image 2 of 3 HP Spectre x360 13-ac023dx Display Replacement: step 2, image 3 of 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Display Replacement: step 3, image 1 of 2 HP Spectre x360 13-ac023dx Display Replacement: step 3, image 2 of 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Display Replacement, Display: step 4, image 1 of 1
    • Lay the laptop flat on the table with the keyboard side facing the table and the motherboard facing up.
  5. HP Spectre x360 13-ac023dx Display Replacement: step 5, image 1 of 3 HP Spectre x360 13-ac023dx Display Replacement: step 5, image 2 of 3 HP Spectre x360 13-ac023dx Display Replacement: step 5, image 3 of 3
    • Using the Phillips #000 screwdriver, remove the four 1.0 mm screws that attach the display to the main body of the computer.
  6. HP Spectre x360 13-ac023dx Display Replacement: step 6, image 1 of 3 HP Spectre x360 13-ac023dx Display Replacement: step 6, image 2 of 3 HP Spectre x360 13-ac023dx Display Replacement: step 6, image 3 of 3
    • Move the metal components that were just unscrewed out of the way to make a clear view of the two display connectors.
    • Flip up both latches that are found at the center of the computer's body where the wires connect to the motherboard. Then release the wires that attach to the display. This will separate the two main parts of the computer.
  7. HP Spectre x360 13-ac023dx Display Replacement: step 7, image 1 of 2 HP Spectre x360 13-ac023dx Display Replacement: step 7, image 2 of 2
    • Separate the display from the bottom half of the computer(motherboard).
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
Jonathan
498 Reputation
4 Guides authored
1 Guide Comment
I couldn’t remove the display without removing the one speaker. In the pictures, you can easily see that he just bent the metal case at the hinge and pried it out.
Ryan Stauffer - Reply
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 50
All Time: 3,366
