Introduction
This guide will help you fix your faulty charge port. Make sure you are wearing the Anti-Static Wrist Strap and remove the battery before beginning this guide to avoid any damage to your computer.
Put on Anti Static Wrist Strap. It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
  • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
  • Flip Computer Upside down.
  • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
Use the plastic opening tool to lift the back case off. Use the plastic opening tools first; metal spudgers can damage your device.
  • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
Remove the six 2.0mm silver screws and the  two 3.2 mm black screws using the PH00 Phillips Screw Head.
  • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
Gently unplug from CONO851 plug, using the plastic opening tool.
  • Gently unplug from CONO851 plug, using the plastic opening tool.
Gently lift up the battery and remove using the plastic opening tools. Gently lift up the battery and remove using the plastic opening tools.
  • Gently lift up the battery and remove using the plastic opening tools.
Remove the two 2.0 mm screws in the charge port bracket using the PH00 screw head.
  • Remove the two 2.0 mm screws in the charge port bracket using the PH00 screw head.
Use the plastic opening tools to remove the bracket.
  • Use the plastic opening tools to remove the bracket.
Lift out and disconnect the charge port. Lift out and disconnect the charge port.
  • Lift out and disconnect the charge port.
3 other people completed this guide.
Laurisa Titterud
1,042 Reputation
6 Guides authored
UWS, Team 1-2, Schneider-Bateman Spring 2016 Member of UWS, Team 1-2, Schneider-Bateman Spring 2016
UWS-SCHNEIDER-BATEMAN-S16S1G2
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 95
All Time: 1,896
