Shop the Holiday Gift Guide
HP ProBook 650 G1 Thermal Paste Replacement
View statistics:
Past 24 Hours:
9
Past 7 Days:
39
Past 30 Days:
134
All Time:
491
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to open the laptop to replace the Thermal Paste. This guide will also help you upgrade the RAM, SSD and CPU inside.
Parts
Tools
    1. HP ProBook 650 G1 Thermal Paste Replacement, Opening the back panel: step 1, image 1 of 3 HP ProBook 650 G1 Thermal Paste Replacement, Opening the back panel: step 1, image 2 of 3 HP ProBook 650 G1 Thermal Paste Replacement, Opening the back panel: step 1, image 3 of 3
      • Unlock and remove the back panel and battery.
      • Disconnect, unscrew and remove the fan.
      • Unscrew the 4 screws holding the CPU heatsink.
      Ask FixBot
    2. HP ProBook 650 G1 Thermal Paste Replacement, Changing the thermal paste: step 2, image 1 of 3 HP ProBook 650 G1 Thermal Paste Replacement, Changing the thermal paste: step 2, image 2 of 3 HP ProBook 650 G1 Thermal Paste Replacement, Changing the thermal paste: step 2, image 3 of 3
      • Clean the old thermal paste from both the cooler and the CPU.
      • Use isopropyl alcohol and cotton swabs or paper towel, but be careful not to press too hard on the CPU.
      • It's also recommended to use compressed air to remove any dust in the laptop and the fan.
      • Here you can upgrade the CPU if needed.
      • Use only enough thermal paste to cover a portion of the pad. Use a spreader if you have one.
      • The thermal paste will apply evenly after you tighten the heatsink.
      • Place the heatsink back into the unit carefully and tighten the screws in an "X" pattern to ensure even pressure. Don't forget to plug in the fan.
      Ask FixBot
    3. HP ProBook 650 G1 Thermal Paste Replacement, Other upgrades: step 3, image 1 of 1
      • Once you have the back cover opened, it is a good opportunity to upgrade the SSD and RAM.
      Ask FixBot
Author
with
Simeon Brankov
10,542 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 134
All Time: 491
