HP ProBook 640 G4 Wi-Fi Card Replacement
  1. HP ProBook 640 G4 Wi-Fi Card Replacement, Lower Case: step 1, image 1 of 2 HP ProBook 640 G4 Wi-Fi Card Replacement, Lower Case: step 1, image 2 of 2
    • Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
    • Captive screws cannot be fully removed.
  2. HP ProBook 640 G4 Wi-Fi Card Replacement: step 2, image 1 of 2 HP ProBook 640 G4 Wi-Fi Card Replacement: step 2, image 2 of 2
    • Insert an opening pick into the seam between the lower case and chassis, and twist it to create a gap.
    • Insert an opening tool into the gap.
    • Use the opening tool to pry around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  3. HP ProBook 640 G4 Wi-Fi Card Replacement, Battery: step 3, image 1 of 3 HP ProBook 640 G4 Wi-Fi Card Replacement, Battery: step 3, image 2 of 3 HP ProBook 640 G4 Wi-Fi Card Replacement, Battery: step 3, image 3 of 3
    • Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
    • Captive screws are not fully removable—they only loosen.
    • Slide and lift the battery out.
  4. HP ProBook 640 G4 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 3 HP ProBook 640 G4 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 2 of 3 HP ProBook 640 G4 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 3 of 3
    • Remove the single 2.5 mm-long Phillips screw securing the Wi-Fi card.
    • Remove the Wi-Fi card.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Timothy Zibrida
523 Reputation
5 Guides authored
UMass Dartmouth, Team 1-5, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-5, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G5
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 45
