HP ProBook 455 G7 SSD Replacement
  1. HP ProBook 455 G7 SSD Replacement, Lower Case: step 1, image 1 of 1
    • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
    • Flip the laptop over so the lower case is facing up.
    • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
  2. HP ProBook 455 G7 SSD Replacement: step 2, image 1 of 3 HP ProBook 455 G7 SSD Replacement: step 2, image 2 of 3 HP ProBook 455 G7 SSD Replacement: step 2, image 3 of 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Lift and remove the lower case.
  3. HP ProBook 455 G7 SSD Replacement, Battery: step 3, image 1 of 3 HP ProBook 455 G7 SSD Replacement, Battery: step 3, image 2 of 3 HP ProBook 455 G7 SSD Replacement, Battery: step 3, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
    • Carefully lift the battery and remove it from the laptop.
  4. HP ProBook 455 G7 SSD Replacement, SSD: step 4, image 1 of 1
    • Remove the single 2 mm-long Phillips #1 screw securing the SSD.
  5. HP ProBook 455 G7 SSD Replacement: step 5, image 1 of 1
    • Gently pull the SSD directly out of its socket.
Your HP ProBook 455 G7 hard drive has been successfully replaced!
Power on the device to ensure the new hard drive is functioning properly
Use a compatible 2.5-inch SATA drive or SSD for replacement. Avoid forcing connectors to prevent damage to the motherboard.
Andiany Reynoso
253 Reputation
3 Guides authored
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 86
