Introduction
Removing the keyboard will require removing the bottom door before turning it over to remove the keyboard. Be wary of any loose components when the laptop is turned right side up.
Slide the two release latches on either side of the battery.
Gently tilt the battery upward and remove it from its socket.
Turn the computer so the bottom is facing towards you.
Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
Remove four 6.0 mm Phillips PM2.5x6.0 screws.
I would add that the third Phillips PM2.5x6.0 screw, not highlighted in the photo above, is located near the RAM module bay, close to the left corner of the RAM module, marked also with a small keyboard sign and a small triangle near. Not removing this third screw, could result in damaging the keyboard (in case one wants just to clean, not replacing the keybord).
Disconnect the keyboard cable by lifting the latch at the center of the system board.
Completely remove the keyboard.
Thanks for doing this in photos and with printed instruction, instead of doing a video…this is far more clear!
15 other people completed this guide.
2 Comments
Precise and clear guide. Great Work!!!
