Fix Your Stuff
Right to Repair
Parts & Tools
  1. Unplug the device from any energy sources. Lift the top cover of the scanner.
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. Carefully pull the frame away from the glass.
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. Put your finger behind the panel with the power button. Then, pull the piece outwards.
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Unscrew the screw inside the power button panel space. Then, unscrew the screw that is across the printer slider.
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  7. Pull the white circuit board outwards which is located under the small screen.
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  8. Pull the memory card reader's circuit board out. Detach the white wiring connector from the back of the circuit board.
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  9. Put your finger behind the small screen. Then, pull it up.
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  10. Pull the printer hood upward.
    • Pull the printer hood upward.
  11. Lift the scanning lid from the lower portion of the printer hood. Lift the scanning lid from the lower portion of the printer hood.
    • Lift the scanning lid from the lower portion of the printer hood.
    Remove torx screw on bottom of assembly in corner near touchsmart screen space.
    Jeff - Reply
  12. Leaving the ribbon connected, lift the sliding scanner off the track. Pull the ribbon cable out of the slot on the scanner circuit board.
    • Leaving the ribbon connected, lift the sliding scanner off the track.
    • Pull the ribbon cable out of the slot on the scanner circuit board.
    • Insert the scanning piece into the rolling track.
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
226 Reputation
3 Guides authored
Cal Poly, Team 2-11, Propen Fall 2012 Member of Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Members
6 Guides authored
One Comment
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,285
