Introduction
If the display is damaged or malfunctioning, use this guide to replace it.
  1. Shut down the computer.
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. Use a Metal Spudger and  remove the rubber foot closet from the bottom  of the  laptop. Use a Metal Spudger and  remove the rubber foot closet from the bottom  of the  laptop.
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. Remove all  of the screws located on the bottom of the laptop:
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. Turn the computer over onto its base, with the computer open and the keyboard facing upward.
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard. Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. Lift the keyboard away from the base of the laptop.
    • Lift the keyboard away from the base of the laptop.
  9. Android Fix Kits
    A new screen or battery is one kit away.
    Shop Now
    Android Fix Kits
    Shop Now
  10. Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  11. Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  12. (You don't NEED to remove this shielding as you can remove the board with it still there.) Remove the adhesive strip. Lift the shield away from the base of the laptop.
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
    This step is not relevant or required...
    ETHREAL1 - Reply
  13. Disconnect the ribbon cables attached to the system board (motherboard). Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard. Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  14. Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger. Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  15. Pull the clipped cables from system board (motherboard). Pull the clipped cables from system board (motherboard).
    • Pull the clipped cables from system board (motherboard).
  16. Remove the system board (motherboard). Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them. Using the Phillips 00 Screw Driver, remove the silver screw.
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  17. Carefully lift the front side of the system board (motherboard).
    • Carefully lift the front side of the system board (motherboard).
  18. Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  19. Release the system board (motherboard) from the base enclosure.
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  20. Using the Phillips 00 Screw Driver, remove 5 Phillips 2.5  x 4.2 screws from  the hinges from the laptop's base.
    • Using the Phillips 00 Screw Driver, remove 5 Phillips 2.5 x 4.2 screws from the hinges from the laptop's base.
  21. Gently pull the display away from the base panel to unhinge. Gently pull the display away from the base panel to unhinge.
    • Gently pull the display away from the base panel to unhinge.
  22. Use a Metal Spudger to pry  the display panel from the outer casing.
    • Use a Metal Spudger to pry the display panel from the outer casing.
    • Start from the top of the display panel and move along the edges and do not to push the metal spudger too far into the screen.
    • Be cautious not to apply heavy pressure to the display panel. This could damage the touch screen.
  23. Open the display panel  to expose the  connecting cables.
    • Open the display panel to expose the connecting cables.
    • Open carefully to avoid causing damage to the connecting cables.
  24. Peel off the adhesive tape and remove the connected cable from the screen. Peel off the adhesive tape and remove the connected cable from the screen.
    • Peel off the adhesive tape and remove the connected cable from the screen.
  25. Lift the circuit board out of the way to expose the wire underneath. Remove the wire from the base of the laptop. Lift the circuit board out of the way to expose the wire underneath. Remove the wire from the base of the laptop.
    • Lift the circuit board out of the way to expose the wire underneath. Remove the wire from the base of the laptop.
    Do the LCD s come with new circuit boards
    Adam Johnson - Reply
Follow these instructions in reverse order to reassemble your device.
3 other people completed this guide.
_ thinhh@uw.edu
246 Reputation
2 Guides authored
UW Tacoma, Team 1-6, Rose Winter 2017 Member of UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 Members
8 Guides authored
2 Comments
Question, why not just do step 21 on?
ETHREAL1 - Reply
You can. Fold the computer all the way over and go from there. The only advantage to opening the bottom would be to disconnect the battery: a highly recommended procedure.
Corvallis Computer - Reply
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 131
All Time: 3,547
