HP Pavilion dv7-1285dx Back Plate Replacement
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: step 1, image 1 of 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: step 2, image 1 of 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: step 3, image 1 of 2 HP Pavilion dv7-1285dx Back Plate Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
Chris Apple
239 Reputation
2 Guides authored
Cal Poly, Team 12-34, Maness Spring 2014 Member of Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,513
