Introduction
This guide would be used if your screen gets damaged or no longer functions. All screws are a PH00 size. It would be advisable to keep track of which screws go where, as there are a lot of screws that will be removed over the course of this guide. Be sure to wear the anti-static guard strap, as that will protect the circuitry from permanent damage from static electricity.
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
Slide the tab all the way over to the left until battery pops out. Lift out and remove battery.
Remove two screws.
Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
Pull out and up on keyboard to remove it.
Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
Grip the ribbon cable near the connection point and gently but firmly pull it out.
Detach the ribbon cables.
Pull from the area closest to the connection port gently but firmly.
Disconnect the connector from the port.
Remove the wire from under the metal tabs.
Let wire hang loose after removing under the tabs.
