Installing HP Pavilion dv6000 Optical Drive
  1. Installing HP Pavilion dv6000 Optical Drive, Optical Drive: step 1, image 1 of 1
    • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
  2. Installing HP Pavilion dv6000 Optical Drive: step 2, image 1 of 1
    • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • The tray will partially pop out of the laptop.
    • Firmly pull the drive straight away from the laptop.
    • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
    • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 8,181
