Introduction
Replace the optical drive in your HP Pavilion dv6000.
Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
Firmly pull the drive straight away from the laptop.
At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
