Introduction
By using the following tools and the following the steps below, you can simply remove your hard drive from your HP Pavilion Sleekbook and replace it with a new one.
  1. Open the laptop and locate the keyboard. Identify the borders of the keyboard. Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard. Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
  2. Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Pop out the black frame found underneath the keyboard using the plastic opening tools. Once the frame is popped out continue to lift the frame gently. Once the frame is popped out continue to lift the frame gently.
    • Pop out the black frame found underneath the keyboard using the plastic opening tools.
    • Once the frame is popped out continue to lift the frame gently.
  5. Locate and remove the silver hard drive cover in the bottom right corner. Locate and remove the silver hard drive cover in the bottom right corner. Locate and remove the silver hard drive cover in the bottom right corner.
    • Locate and remove the silver hard drive cover in the bottom right corner.
  6. Detach and remove the hard drive from the black plug located to the right of the hard drive.
    • Detach and remove the hard drive from the black plug located to the right of the hard drive.
12 other people completed this guide.
Rashed
670 Reputation
1 Guide authored
USF Tampa, Team 3-3, Hickman Winter 2015 Member of USF Tampa, Team 3-3, Hickman Winter 2015
USFT-HICKMAN-W15S3G3
4 Members
5 Guides authored
5 Comments
Fatto per il modello 15-b131el!!
Simone Milesi - Reply
This technician has left out several crucial steps for this repair several screws on the bottom and several underneath the keyboard before the laptop casing will come apart, common sense for a tech but a how-to should not leave these details out.
dloeper2391 - Reply
These instructions ruined my friends laptops. PLEASE do not post directions like this if you don’t know what you ‘re doing as folks like me will mistakenly assume that you do & attempt this and then damage cables. VERY, VERY careful folks! Cost me $200 for a replacement laptop.
Andre Bajew - Reply
If you do not remove the screws you will crack the keyboard and cover.
HometownComputers - Reply
WIll it support any SSD drive to upgrade from basic HDD?
Gajanan Thirumoolanathan - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 94
All Time: 13,301
