Introduction
The battery is one of the main components of a laptop: used to keep the laptop on and running. If the battery is failing to hold charge, or the computer will not turn on at all, then a battery replacement may be necessary. This guide will aid in replacing the defective battery with a replacement.
  1. Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done! Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done! Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
Eric Sowersby
413 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 457
