Introduction
With this replacement guide you will learn how to replace the screen as well as the digitizer for an HP Pavilion 14-v062us.
Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
Remove rectangular rubber tops with a spudger
Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
Remove plastic edge covering with the blue plastic opening tool.
Remove two 4.63 mm PH#1 screws located under plastic edge covering.
Using the spudger, wedge tool in between screen and laptop
Pry open screen with spudger and your hands
Locate the white and brown wiring that connects to the digitizer and the screen.
Cut through the clear part of tape attached to the brown latch and white wiring.
Disconnect the wiring, by lifting the brown latch with the blue plastic opening tool and pulling the white wire at the same time.
Lift off the digitizer. If you need to replace the digitizer stop here and replace this part.
If you need to replace the screen, then continue
