Introduction
Wi-Fi cards are often replaced to gain faster internet connection. This guide where show you where the Wi-Fi card is located and how to replace it.
Turn the laptop over.
Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
Unpeel the connector ribbon from its position on the motherboard.
With the internal hardware exposed, disconnect the battery cable from the motherboard.
If tightly fastened, gently wiggle the plug out of the jack.
Remove the two Wi-Fi antenna cables that are attached to the Wi-Fi card by pulling them up.
Using your fingers, pull the Wi-Fi card located on the right side of the detached motherboard out of its place.
