HP Officejet Pro 6230 Printer Power Adaptor Replacement
  1. HP Officejet Pro 6230 Printer Power Adaptor Replacement, Power Adapter: step 1, image 1 of 2 HP Officejet Pro 6230 Printer Power Adaptor Replacement, Power Adapter: step 1, image 2 of 2
    • Turn the printer around and locate the back panel for power.
    • Note: If you are unsure where the panel is located, look in the back right corner. The panel has “100-240V~50/60 Hz 700 mA” inscribed on it.
  2. HP Officejet Pro 6230 Printer Power Adaptor Replacement: step 2, image 1 of 1
    • Unscrew the 0.8 mm screw holding in the panel using a T6 Torx screwdriver.
    • Note: Rotate the screw counterclockwise to loosen. Keep it in a safe place.
  3. HP Officejet Pro 6230 Printer Power Adaptor Replacement: step 3, image 1 of 1
    • Remove the HP AC Power Adapter from the slot.
  4. HP Officejet Pro 6230 Printer Power Adaptor Replacement: step 4, image 1 of 1
    • Locate the blue/green/red wire attached to the back of the adapter.
  5. HP Officejet Pro 6230 Printer Power Adaptor Replacement: step 5, image 1 of 1
    • Unplug the current adapter from the wire.
    • Grasp the end of the connector, not the wires, to pull it out.
  6. HP Officejet Pro 6230 Printer Power Adaptor Replacement: step 6, image 1 of 1
    • Affix the new adapter to the same wire.
Natalie Carmona
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,073
