Remove the battery by moving the points marked with an arrow towards the inside.
To reassemble the device, follow the steps of this guide in reverse order.
8 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
2 Comments
I did a similar clone hd to ssd replacement on Hewlett Packard 15-bs058ca Laptop. It was a full bottom removal with the components attached to the bottom of the keyboard and screen combo. There were hidden screws under the rubber feet. A lot of finicky spludger work all around the outer shell was needed to pry the bottom from the top. The good thing was there are no cables between the bottom shell and the rest of the laptop.
After that the hard-disk change was similar to the one above.
HP does have a manual (http://h10032.www1.hp.com/ctg/Manual/c05...) but it does not mention the care needed to pry apart the shell.
Next time I do this I will take photos and up load them.
