Introduction
Use this guide to replace or upgrade the SSD in your HP EliteBook 840 G8 laptop.
This laptop has one slot that supports an M.2 2280 PCIe SSD up to 2 TB. For more in‑depth SSD specifications, take a look at the HP Service Manual.
Before starting this repair, consider backing up your current drive. If necessary, familiarize yourself with a disk cloning utility so you’ll be ready to transfer your data to the new drive.
Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
Position your laptop so the rear edge (with the screen hinge) is closest to you.
Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
Use your spudger to pry up the cover to release the clip securing it.
Leave the spudger inserted under the bottom cover for the next step.
Position your laptop so the front edge (opposite the screen hinges) is closest to you.
Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
Use tweezers or your fingers to peel up the bottom edge of the SSD cover.
Fold the SSD cover over, onto the memory module cover.
Use a Phillips screwdriver to remove the 2.4 mm‑long screw securing the SSD.
Grip the SSD by its edges and pull it straight out of its socket to remove it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
