HP Elitebook 840 G8 Battery Replacement (Revivekit)
  1. HP Elitebook 840 G8 Battery Replacement (Revivekit), Before you begin: step 1, image 1 of 2 HP Elitebook 840 G8 Battery Replacement (Revivekit), Before you begin: step 1, image 2 of 2
    • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
    • Save your work, fully shut down your laptop, and unplug all cables.
  2. HP Elitebook 840 G8 Battery Replacement (Revivekit), Unfasten the bottom cover: step 2, image 1 of 2 HP Elitebook 840 G8 Battery Replacement (Revivekit), Unfasten the bottom cover: step 2, image 2 of 2
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
  3. HP Elitebook 840 G8 Battery Replacement (Revivekit), Release the bottom cover clips: step 3, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Release the bottom cover clips: step 3, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Release the bottom cover clips: step 3, image 3 of 3
    • Position your laptop so the rear edge (with the screen hinge) is closest to you.
    • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
    • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
    • Use your spudger to pry up the cover to release the clip securing it.
    • Leave the spudger inserted under the bottom cover for the next step.
  4. HP Elitebook 840 G8 Battery Replacement (Revivekit): step 4, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 4, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 4, image 3 of 3
    • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
    • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
  5. HP Elitebook 840 G8 Battery Replacement (Revivekit): step 5, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 5, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 5, image 3 of 3
    • Reinsert the flat end of a spudger near the ELITEBOOK text.
    • Repeat the previous step for the other side of the cover to release the remaining clips.
  6. HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the bottom cover: step 6, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the bottom cover: step 6, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the bottom cover: step 6, image 3 of 3
    • Lift and remove the bottom cover.
    • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
    • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
  7. HP Elitebook 840 G8 Battery Replacement (Revivekit), Disconnect the battery: step 7, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Disconnect the battery: step 7, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Disconnect the battery: step 7, image 3 of 3
    • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
    • Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
  8. HP Elitebook 840 G8 Battery Replacement (Revivekit), Unclip the speaker cable: step 8, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Unclip the speaker cable: step 8, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Unclip the speaker cable: step 8, image 3 of 3
    • Be careful not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a spudger or your fingers to lift the speaker cable out of its clips on the bottom edge of the battery.
  9. HP Elitebook 840 G8 Battery Replacement (Revivekit), Prepare the battery removal kit: step 9, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Prepare the battery removal kit: step 9, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Prepare the battery removal kit: step 9, image 3 of 3
    • Open your Revivekit and grab the empty cardboard tray.
    • This tray will be used to remove and safely store your old battery.
    • Open the cardboard tray.
  10. HP Elitebook 840 G8 Battery Replacement (Revivekit): step 10, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 10, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 10, image 3 of 3
    • Remove the plastic liners from both adhesive strips.
  11. HP Elitebook 840 G8 Battery Replacement (Revivekit), Adhere the cardboard to the battery: step 11, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Adhere the cardboard to the battery: step 11, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Adhere the cardboard to the battery: step 11, image 3 of 3
    • Align the top edge of the cardboard with the top edge of the battery, without covering the battery screws. Make sure the battery is fully covered.
    • Once properly aligned, secure the cardboard to the battery with the adhesive strips by firmly pressing it into place with your fingers.
  12. HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the battery screws: step 12, image 1 of 2 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the battery screws: step 12, image 2 of 2
    • Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the top edge of the battery.
  13. HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the battery: step 13, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the battery: step 13, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the battery: step 13, image 3 of 3
    • The battery should stay adhered to the cardboard tray—be gentle when removing it.
    • Lift the top edge of that battery and slide the tabs on the bottom edge out of their slots.
    • Remove the battery.
  14. HP Elitebook 840 G8 Battery Replacement (Revivekit): step 14, image 1 of 2 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 14, image 2 of 2
    • Close the cardboard tray so the old battery is safely enclosed, then set it aside.
    • Take your old battery to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program. Follow any instructions included with your Revivekit.
  15. HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the replacement battery: step 15, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the replacement battery: step 15, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the replacement battery: step 15, image 3 of 3
    • Remove the cardboard tray with your replacement battery enclosed and carefully open the tray.
  16. HP Elitebook 840 G8 Battery Replacement (Revivekit), Install the replacement battery: step 16, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Install the replacement battery: step 16, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Install the replacement battery: step 16, image 3 of 3
  17. HP Elitebook 840 G8 Battery Replacement (Revivekit): step 17, image 1 of 2 HP Elitebook 840 G8 Battery Replacement (Revivekit): step 17, image 2 of 2
    • Use a Phillips screwdriver to install the four 4.5 mm‑long screws along the top edge of the battery.
  18. HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the cardboard: step 18, image 1 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the cardboard: step 18, image 2 of 3 HP Elitebook 840 G8 Battery Replacement (Revivekit), Remove the cardboard: step 18, image 3 of 3
    • Slowly peel the cardboard away from the battery and remove it.
  19. HP Elitebook 840 G8 Battery Replacement (Revivekit), Put your old battery in the box: step 19, image 1 of 1
    • Place the tray with your old battery into the Revivekit's cardboard box.
    • After your repair, ship or bring this box to a certified recycler so the battery can be safely recycled.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Carsten Frauenheim
160,467 Reputation
439 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 64
Past 30 Days: 232
All Time: 1,747
