HP EliteBook x360 830 G6 CMOS Battery Replacement
  1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Unfasten the back cover: step 1, image 1 of 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: step 2, image 1 of 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: step 2, image 2 of 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: step 3, image 1 of 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: step 3, image 2 of 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: step 4, image 1 of 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: step 4, image 2 of 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: step 4, image 3 of 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: step 5, image 1 of 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: step 5, image 2 of 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: step 6, image 1 of 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: step 6, image 2 of 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: step 6, image 3 of 3
    • Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
  7. HP EliteBook x360 830 G6 CMOS Battery Replacement: step 7, image 1 of 1
    • Remove the CMOS battery from its housing by pulling up the small, black plastic tab that is holding it in place.
Brody Reder
301 Reputation
3 Guides authored
IUPUI, Team 3-3, Harley Spring 2024 Member of IUPUI, Team 3-3, Harley Spring 2024
IUPUI-HARLEY-S24S3G3
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 202
All Time: 4,116
