HP EliteBook x360 1030 G3 WWAN Card Replacement
  1. HP EliteBook x360 1030 G3 WWAN Card Replacement, Bottom Cover: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
    Ask FixBot
  2. HP EliteBook x360 1030 G3 WWAN Card Replacement: step 2, image 1 of 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
    Ask FixBot
  3. HP EliteBook x360 1030 G3 WWAN Card Replacement, WWAN Card: step 3, image 1 of 2 HP EliteBook x360 1030 G3 WWAN Card Replacement, WWAN Card: step 3, image 2 of 2
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the mobile cell service/WWAN antennas.
    • Take note of which wire goes where, as mixing these cables will cause the mobile cell service/WWAN to stop working.
    Ask FixBot
  4. HP EliteBook x360 1030 G3 WWAN Card Replacement: step 4, image 1 of 1
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
    Ask FixBot
  5. HP EliteBook x360 1030 G3 WWAN Card Replacement: step 5, image 1 of 2 HP EliteBook x360 1030 G3 WWAN Card Replacement: step 5, image 2 of 2
    • Carefully pull out the card by sliding it to the left.
    Ask FixBot
Shea Charkowsky
1,032 Reputation
3 Guides authored
Cal Poly, Team S2-G9, Maness Spring 2019 Member of Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 67
All Time: 3,625
