HP EliteBook 845 G8 Touchpad Replacement
  1. HP EliteBook 845 G8 Touchpad Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 845 G8 Touchpad Replacement, Before you begin: step 1, image 2 of 2
    • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
    • Save your work, fully shut down your laptop, and unplug all cables.
  2. HP EliteBook 845 G8 Touchpad Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 845 G8 Touchpad Replacement, Unfasten the bottom cover: step 2, image 2 of 2
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
  3. HP EliteBook 845 G8 Touchpad Replacement, Release the bottom cover clips: step 3, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement, Release the bottom cover clips: step 3, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement, Release the bottom cover clips: step 3, image 3 of 3
    • Position your laptop so the rear edge (with the screen hinge) is closest to you.
    • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
    • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
    • Use your spudger to pry up the cover to release the clip securing it.
    • Leave the spudger inserted under the bottom cover for the next step.
  4. HP EliteBook 845 G8 Touchpad Replacement: step 4, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement: step 4, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement: step 4, image 3 of 3
    • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
    • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
  5. HP EliteBook 845 G8 Touchpad Replacement: step 5, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement: step 5, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement: step 5, image 3 of 3
    • Reinsert the flat end of a spudger near the ELITEBOOK text.
    • Repeat the previous step for the other side of the cover to release the remaining clips.
  6. HP EliteBook 845 G8 Touchpad Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement, Remove the bottom cover: step 6, image 3 of 3
    • Lift and remove the bottom cover.
    • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
    • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
  7. HP EliteBook 845 G8 Touchpad Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement, Disconnect the battery: step 7, image 3 of 3
    • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
    • Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
  8. HP EliteBook 845 G8 Touchpad Replacement, Remove the battery screws: step 8, image 1 of 2 HP EliteBook 845 G8 Touchpad Replacement, Remove the battery screws: step 8, image 2 of 2
    • Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the battery.
  9. HP EliteBook 845 G8 Touchpad Replacement, Remove the battery: step 9, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement, Remove the battery: step 9, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement, Remove the battery: step 9, image 3 of 3
    • Lift the top edge of that battery and slide the tabs on the bottom edge out of their slots.
    • Remove the battery.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  10. HP EliteBook 845 G8 Touchpad Replacement, Disconnect the touchpad cables: step 10, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement, Disconnect the touchpad cables: step 10, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement, Disconnect the touchpad cables: step 10, image 3 of 3
    • Use a spudger to lift the hinged locking flap on one of the three ZIF connectors near the top right corner of the touchpad.
    • Use tweezers to gently pull the cable straight out of its socket.
  11. HP EliteBook 845 G8 Touchpad Replacement: step 11, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement: step 11, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement: step 11, image 3 of 3
    • Repeat the previous step to disconnect the two remaining touchpad cables.
  12. HP EliteBook 845 G8 Touchpad Replacement, De‑route the speaker cable: step 12, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement, De‑route the speaker cable: step 12, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement, De‑route the speaker cable: step 12, image 3 of 3
    • Use a spudger or your fingers to lift the entire speaker cable out of its clips on the bottom edge.
  13. HP EliteBook 845 G8 Touchpad Replacement, Remove the touchpad screws: step 13, image 1 of 2 HP EliteBook 845 G8 Touchpad Replacement, Remove the touchpad screws: step 13, image 2 of 2
    • Use a Phillips screwdriver to remove the five 2.2 mm‑long screws securing the touchpad.
  14. HP EliteBook 845 G8 Touchpad Replacement, Remove the touchpad: step 14, image 1 of 3 HP EliteBook 845 G8 Touchpad Replacement, Remove the touchpad: step 14, image 2 of 3 HP EliteBook 845 G8 Touchpad Replacement, Remove the touchpad: step 14, image 3 of 3
    • Lift the bottom corners of the touchpad with your fingers and slide the top edge out from under the motherboard.
    • Slide the touchpad under the speaker cable and remove it.
    • During reassembly, make sure no cables get stuck under the touchpad when inserting it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Carsten Frauenheim
162,343 Reputation
439 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 54
All Time: 461
