HP EliteBook 840 G9 Touchpad Replacement
  1. HP EliteBook 840 G9 Touchpad Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement, Before you begin: step 1, image 2 of 2
    • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
    • Save your work, fully shut down your laptop, and unplug all cables.
  2. HP EliteBook 840 G9 Touchpad Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement, Unfasten the bottom cover: step 2, image 2 of 2
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    • Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
  3. HP EliteBook 840 G9 Touchpad Replacement, Release the bottom cover clips: step 3, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement, Release the bottom cover clips: step 3, image 2 of 2
    • Position your laptop so the rear edge (with the screen hinge) is closest to you.
    • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
    • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
    • Use your spudger to pry up the cover to release the clip securing it.
    • Leave the spudger inserted under the bottom cover for the next step.
  4. HP EliteBook 840 G9 Touchpad Replacement: step 4, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 4, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 4, image 3 of 3
    • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
    • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
  5. HP EliteBook 840 G9 Touchpad Replacement: step 5, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 5, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 5, image 3 of 3
    • Reinsert the flat end of a spudger near the ELITEBOOK text.
    • Repeat the previous step for the other side of the cover to release the remaining clips.
  6. HP EliteBook 840 G9 Touchpad Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement, Remove the bottom cover: step 6, image 3 of 3
    • Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
    • Lift and remove the cover.
    • The cover should come away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips.
    • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Firmly press around the perimeter of the cover to engage all the clips.
  7. HP EliteBook 840 G9 Touchpad Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement, Disconnect the battery: step 7, image 3 of 3
    • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
    • Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
  8. HP EliteBook 840 G9 Touchpad Replacement, Remove the battery screws: step 8, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement, Remove the battery screws: step 8, image 2 of 2
    • Be careful not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the four 4.6 mm‑long screws securing the battery.
  9. HP EliteBook 840 G9 Touchpad Replacement, Remove the battery: step 9, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement, Remove the battery: step 9, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement, Remove the battery: step 9, image 3 of 3
    • Lift the top edge of that battery and slide the tabs on the bottom edge out of their slots.
    • Remove the battery.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  10. HP EliteBook 840 G9 Touchpad Replacement, Disconnect the trackpad cables: step 10, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement, Disconnect the trackpad cables: step 10, image 2 of 2
    • Gently slide the flat end of a spudger under the ribbon cable near the top right corner of the touchpad to separate the adhesive.
  11. HP EliteBook 840 G9 Touchpad Replacement: step 11, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 11, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 11, image 3 of 3
    • Use a spudger to lift the hinged locking flap on the ZIF connector near the top right corner of the touchpad.
    • Use tweezers to gently pull the cable straight out of its socket.
  12. HP EliteBook 840 G9 Touchpad Replacement: step 12, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement: step 12, image 2 of 2
    • Gently slide the flat end of a spudger under the small, brown ribbon cable near the center of the touchpad's top edge to separate the adhesive.
  13. HP EliteBook 840 G9 Touchpad Replacement: step 13, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 13, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 13, image 3 of 3
    • Use a spudger to lift the hinged locking flap on the smaller ZIF connector on the center of the motherboard's bottom edge.
  14. HP EliteBook 840 G9 Touchpad Replacement: step 14, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 14, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 14, image 3 of 3
    • Repeat the previous step to disconnect the ZIF connector just to the left of the previous one.
  15. HP EliteBook 840 G9 Touchpad Replacement: step 15, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 15, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 15, image 3 of 3
    • Use tweezers to lift the thin, clear piece of tape from the small board just to the left of the touchpad.
  16. HP EliteBook 840 G9 Touchpad Replacement: step 16, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 16, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 16, image 3 of 3
    • Use the point of a spudger to lift the hinged locking flap on the smaller ZIF connector on the board (with an orange cable).
  17. HP EliteBook 840 G9 Touchpad Replacement, Remove the touchpad screws: step 17, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement, Remove the touchpad screws: step 17, image 2 of 2
    • Use a Phillips screwdriver to remove the seven 2.2 mm‑long screws securing the touchpad.
  18. HP EliteBook 840 G9 Touchpad Replacement, Remove the touchpad: step 18, image 1 of 2 HP EliteBook 840 G9 Touchpad Replacement, Remove the touchpad: step 18, image 2 of 2
    • Use a spudger to lift the bottom edge of the touchpad until you can grip it with your fingers.
  19. HP EliteBook 840 G9 Touchpad Replacement: step 19, image 1 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 19, image 2 of 3 HP EliteBook 840 G9 Touchpad Replacement: step 19, image 3 of 3
    • Grab the touchpad's bottom edge and pull to slide its top edge out from under the motherboard.
    • Remove the touchpad.
    • During reassembly, make sure no cables get stuck under the touchpad when inserting it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Day
165,355 Reputation
1,047 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,300 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 78
All Time: 690
