Introduction
The HP EliteBook 840 G3 received a 10 out of 10 on our repairability scale, for all of its components are modular and accessible. Big positives include that its battery, RAM, and SSD are all accessible and removable, and the display is very easy to replace if broken.
Parts
No parts specified.
Reference shots: packaging US4, rear and open.
The battery is immediately accessible under the lower case.
Removal is quick. The battery is held by two captive Phillips screws (no adhesive) and can be lifted out with a handy pull tab.
Easy battery removal is a high mark for repairability, as all batteries will eventually wear out and need replacement.
The (free, online) HP repair manual says to remove the keyboard before the motherboard, so we do that.
The keyboard screws are labeled by size, making reassembly easier.
The keyboard can be pried out after removing two Phillips screws.
Now we remove the midframe. It's held in by three varieties of Phillips 0 screws (M2.5 x 5, M2.0 x 7, and M2.5 x 2.5) — 26 in total.
Without documentation it'd be tough to know precisely which 26 screws are securing the midframe due to it's spread-out design.
Luckily, HP's got us covered by providing a service manual for this device.
Removing the next component, the heat-sink/fan combo is more straightforward. Its six screws are numbered to indicate order of removal. This simplifies reassembly.
After removing screws and disconnecting cables, the motherboard is ready to slide free.
The display connector has a convenient tab for handling, making the delicate re-insertion procedure simpler and safer.
With the screws removed, the motherboard is easily removed from the lower case.
Unlike some notebooks that have separate I/O boards for DC-in or an SD card reader, all ports except a USB and VGA live directly on the motherboard.
Lower palmrest peripherals are comprised of:
The trackpad, which is secured by grounding tape and Phillips 0 screws.
The smartcard reader assembly (including status LEDs), secured by Phillips screws.
The I/O board (USB and VGA), secured by Phillips screws.
Port break-out boards make for less expensive replacements of high-wear components like USB ports.
The display bezel can be a first-out component, not requiring the above disassembly.
The bezel is secured with plastic clips, prying is relatively simple, but care must be taken to avoid scratching the unprotected display.
The LCD is secured with four screws and has a single display data interconnect cable plugged into the back.
The display frame is simply attached to the palm rest with four Phillips screws.
The palm rest contains final peripheral components including: fingerprint scanner, speakers, and the power button board.
The above components are modular and not high-wear components. The power button is the most likely to fail and is reasonably accessible.
The HP EliteBook 840 G3 earns a 10 out of 10 on our repairability scale (10 is the easiest to repair):
RAM, SSD, and battery are easily accessible and removable.
All moving parts, including keyboard, trackpad, and pointing stick are modular and can be quickly replaced.
The display is immediately replaceable, without any unnecessary disassembly.
All screws are Phillips #0 and #00.
Manufacturer provides user-accessible repair documentation and sells replacement parts.
24 other people completed this guide.
6 Comments
i “am blessed with a few laptop”s , that the internet connection , isn”t ! working with wifi etc…i still have hope for…them that “i” can fix them, , now i”am just checking-in on a hp touchtab [ the dis contenued one2011 ? not sure now i see how great !! you did on this laptop humm ,i just got inspiration ! to go foe-it! good job , god bless you & yours
Hloo sir my hp630 has some problem ,when I start the button the power button lights and caps lock lights are on and the fan starts but the screen remain black nothing appear on it and after 15-20sec it shut down automatically what will the problem
Just letting anyone interested know, I’ve successfully swapped standard HD TN (SVA) display for FHD IPS (laptop-lcd-screen.co.uk https://bit.ly/2DWXV3q). Few minutes of horror, when new screen wouldn’t show anything, but after two restarts it came alive. Also, be extremely careful separating bottom portion of the bezel. I managed destroying my old screen while thinking it went smoothly (few cracks inside the display itself).
Hello sir ,im beging you to give me a hand over here . my hp elitebook G3 840 has fall in the water so now the motherboard is oxidized and i want to know if it is possible to chnage it or not , and if it s possible , should i use any motherboard or there is a specific one i should buy .thank you for your answer in advance
Use soap water n wash the motherboard using wall paint brush dry it for a whole in the sun. Always works for me.
Am a laptop technician here in Kenya
