HP EliteBook 840 Aero G8 Bottom Cover Replacement
    1. HP EliteBook 840 Aero G8 Bottom Cover Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 840 Aero G8 Bottom Cover Replacement, Before you begin: step 1, image 2 of 2
      • Before starting your repair, save your work, fully shut down your laptop, and unplug all cables.
      Ask FixBot
    1. HP EliteBook 840 Aero G8 Bottom Cover Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 840 Aero G8 Bottom Cover Replacement, Unfasten the bottom cover: step 2, image 2 of 2
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
      Ask FixBot
    2. HP EliteBook 840 Aero G8 Bottom Cover Replacement, Release the bottom cover clips: step 3, image 1 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement, Release the bottom cover clips: step 3, image 2 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement, Release the bottom cover clips: step 3, image 3 of 3
      • Position your laptop so the rear edge (with the screen hinge) is closest to you.
      • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
      • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
      • Use your spudger to pry up the cover to release the clip securing it.
      • Leave the spudger inserted under the bottom cover for the next step.
      Ask FixBot
    3. HP EliteBook 840 Aero G8 Bottom Cover Replacement: step 4, image 1 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement: step 4, image 2 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement: step 4, image 3 of 3
      • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
      • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
      Ask FixBot
    4. HP EliteBook 840 Aero G8 Bottom Cover Replacement: step 5, image 1 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement: step 5, image 2 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement: step 5, image 3 of 3
      • Reinsert the flat end of a spudger near the ELITEBOOK text.
      • Repeat the previous step for the other side of the cover to release the remaining clips.
      Ask FixBot
    5. HP EliteBook 840 Aero G8 Bottom Cover Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 840 Aero G8 Bottom Cover Replacement, Remove the bottom cover: step 6, image 3 of 3
      • Lift and remove the bottom cover.
      • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
      • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
      Ask FixBot
Spencer Day
199,958 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
82,494 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 50
All Time: 739
