HP EliteBook 830 G6 Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
124
All Time:
668
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If the battery in your HP EliteBook 830 G6 is no longer working, it is damaged, or it is no longer holding a charge follow this guide to replace your laptops battery.
Tools
    1. HP EliteBook 830 G6 Battery Replacement, Bottom Cover Panel: step 1, image 1 of 1
      • Use a JIS #1 screwdriver to remove the five 10.7 mm screws from the bottom cover.
      Ask FixBot
    2. HP EliteBook 830 G6 Battery Replacement: step 2, image 1 of 1
      • With your spudger you will pry off the bottom panel with some force.
      Ask FixBot
    1. HP EliteBook 830 G6 Battery Replacement, Battery: step 3, image 1 of 2 HP EliteBook 830 G6 Battery Replacement, Battery: step 3, image 2 of 2
      • Use a JIS #1 screwdriver to remove the five 4.7 mm screws securing the battery.
      Ask FixBot
    2. HP EliteBook 830 G6 Battery Replacement: step 4, image 1 of 1
      • Gently disconnect the battery cord from motherboard using a plastic spudger.
      Ask FixBot
    3. HP EliteBook 830 G6 Battery Replacement: step 5, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Haley Johnson
211 Reputation
2 Guides authored
Texas Tech, Team 37-5, Allen Fall 2025 Member of Texas Tech, Team 37-5, Allen Fall 2025
TTU-ALLEN-F25S37G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 124
All Time: 668
